When setting up a D60, are you guys using a set up bearing for your carrier, are you pulling the stock carrier bearings on and off or are you making your own set up bearings by honing standard bearings?
I’m getting ready to set mine up and would like to make it as uncomplicated as possible.
I’ve done several forklifts but never a 60.
I used to care but....... things have changed
