I was just seeing if anyone else had run into the same issue. I called milodon before ordering the pan and was told that the pan would work with my k member and that it "fit everything without issue." I knew doing the big block swap mounts was questionable with the qa1 k because i also called them and got "no clue, it's made for a small block." Guess i got spoiled doing drag cars because i never ran into these issues. Pan is off getting 3" chopped of the right side, left mounting pad has been modified for oil pump clearance. Hopefully it all goes back together smoothly
