You might not need a relay but sometimes using a relay makes the whole system safer. For example, you can eliminate the extra current draw in the passenger compartment by wiring the switch to close a ground. Then use the ground to switch the relay. Closing grounds on the switch panel is safer than having a bunch of 12 volt wires running around under the dash.
