I would check the engine mount, if stock type rubber, it may be compressed some lowering the engine. Maybe switch to a more durable mount that won't compress like the after market poly types.
Also sometimes people have a washer to take up some space where the Idler arm bolts to the K, if so move the washer to the bottom to raise the idler up a little.
