Thanks for the effort.Those bolts are NLA and are not regular bolts. I spent 10 hours cleaning everything up and freeing up those bolts so everything should be goo to go. We will see if Murphy stops by again this morning.I found a pair of really clean UCA's with the bolts in New Mexico. When they arrive I will refurbish them and install on the truck later. By the way....the FSM and the parts manual are both wrong as far as this goes. The illustrations in both are confusing and very vague.
