92 model v6,i did the wiggle test on the wiring today to no avail,then i had the lid off of the under hood relay/fuse box,the auto shutdown relay was warm to the touch,not burn your finger hot but warmer than i thought it should be,is that normal or should the relays be cool/room temp?,this was after a drive and warmup
my ladder of success is missing some rungs
