Originally Posted by Stanton
The circled bolts. One on each side. These are NOT seat belts or exhaust hangers.n to the frame rails for assembly at the factory!!
Probably NOT tsk All the main body parts for the rear half of unibody cars are welded on, not bolted shruggy
If they bolted them together before welding it would take a lot more than two bolts, correct? work shruggy
The exhaust hanger brackets should be welded onto the bottom of the floor near where your bolts are confused
I wish I had the correct answer for you but I don't whiney
