I'm installing a set VS 50145 R on a 1969 Dodge 440 with stock valve covers. The Factory service manual reads 40 inch pounds of torque but the instructions that came with the gaskets reads 90 inch pounds of torque. Which torque spec should I use? Thank You
torque specs are for the most part for the gasket cuz it is what is being compressed. Go with the their 90 & crisscross multiple times coming up on it & 90 ain't a requirement, on VC's to some extent go with how it feels.
