hi con, double check axle splines on that sure grip. the older sure grip with the 27 spline uses Timken LM102910 1" 25/32 id bearings and LM102949 2"57/64 od races. the newer 8.25 29 spline uses Timken LM603049 bearings and LM603012 races. ronnie
