Originally Posted By Cab_Burge
Originally Posted By vinnyd76
What brand main and rod bearings do you prefer when rebuilding your Mopar engine?
Which motor and what application?
A pump gas street motor doesn't have the same needs as a high RPM drag race motor, correct?
I like and use Federal Mogul, Speed Pro or Seal Power rods and main bearings for most of my BB street and drag race motors now up
Duro Bond cam bearings also thumbs
340 - mostly used on the street with pump gas... occasional strip (pure stock/FAST).
