Hi folks. I'm heading into uncharted waters for me. I'm building a 68 b body wagon, and in want it to handle well. Have good road manners and such. Whose torsion bars and size do you like. I was looking at 1.03 diameter bars, and a sway bar. Recommendations? Horror stories? Thanks for the input.
What engine are you running? The weight of the motor is a variable that you want to consider.
I have a small block with aluminum heads and intake on a 71 Satellite and I run 1.03 torsion bars on that. 1.03 at 41" long is about 205/lbs/inch spring rate. If you have a big block you might want something a little stronger.
