What I do is stick the probe in boiling water and see what temp it picks up. And also use a temperature gun in a few spots on the engine when it's running to see how that compares to the gauge. Neither are dead on but at least give you the general idea if it's working or not.
If the probe needs ground you'll need to clip a ground on to the threads if you remove it from the engine.
