Originally Posted By rdakota340
Originally Posted By Transman
An old technician trick - get up to about 35-40 mph and throw in park for a second.
No longer.
Then take it out of park real quick.
It will make an atrocious noise but the vibration will break the governor valve and weight loose.
It won’t break parts, won’t damage anything if you do it quick.
If it doesn’t break loose then you have to pull the extension housing.
A fresh build like you say - probably got some dirt in it.
Try this first it's worked plenty of times for me.
eek I read about this on another forum, but I don't feel like this would result in anything but catastrophic failure. Awful sounds rarely if ever result in something positive.
1970 EK2 T/A 727
