I never really considered the gm hei route...... I had more of a “just put an msd in it” mind set.
But I can see the attraction to using a cheaper, readily available system like the hei conversion.
I’d def try it.
I like the idea of getting rid of the ballast resistor and running a modern style coil.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
