Originally Posted By HotRodDave
I would almost bet it's head gaskets also.
My advice, Get a 6.4 cam and valve springs while your in there and carefully check every lifter, roll it on a clean piece of glass and listen for anything thats not a normal rolling sound and replace the bad ones, even better just buy 16 new ones if you can swing it. Machine the heads to make sure they seal up real good, while they have em tell em to take .020 off, this will give you a smidgen more compression and a tiny bit more lifter pre-load to keep lifter tick at bay as the PRs are just barely long enough, almost not long enough. Throw in a new water pimp while you at it.
I was planning on getting the heads gone through. I do not want to do this again. I am assuming the 6.4 stuff won't affect the computer?
Does anyone recommend a gasket kit?
Heads are just about ready to come off. Looks like there was coolant mixing in the oil as well. It had just started spraying on the underside of the valve covers.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
