Also Pick your tire on future likely availability if this a driver, which seems always risky nowadays. I had to wait nearly a year to get my replacement 295's, although the supply seems to have improved in the last year or so. Tires are the most important handling decision one makes, and wider is always better.
Anymore, tire sizes are changing so rapidly that the above bolded can be pretty relevant to continued availability. If you can find a size that was available OEM on a vehicle, or better yet, several vehicles, the odds of it being around longer are much improved over an oddball size, perfect fit, but diminishing availability tire.
