I assume this is in a road race car. A drag seat would be useless (and dangerous) for you. Different applications will require different seating solutions. A drag car with a roll bar will not use the same set up as a 25.5 or 25.1 chassis. Street car that will be driven miles? Something completely different.
This road race 9119 seat is actually used in drag setups as well. Probably due to its high safety factor and being only 14 lbs.
https://timmcamis.com/shop/racetech-carbon-kevlar.html Racetech also has a 229 seat for drag cars with a very similar back mount design.
