Yes, the spring is still in place in the shuttle valve, so removing the blocker rod is easy. Need to buy/find a ball, but that should not be hard either. Guess I'll make those changes and see how it works when I eventually get the car back on the road. Worst case is I might have to change out the valve body. Thanks again for your help.
John
