Many race pistons that use spiro-lox, use two on each side.
Not that it really matters at this point........ it should come apart anyway, especially if you don’t know if your pistons used singles or doubles per side.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
