Need a couple measurements if anyone has a hellcat with damper off. Need to know length of timing gear/oil pump drive sprocket? Also with damper off how much crank snout sticks out past the pump drive/timing sprocket? Looking like the ATI hellcat damper will need a spacer on this Frankenstein mock up Im doing.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
