Originally Posted By hemi-itis
Originally Posted By krautrock
Originally Posted By Jeremiah
My application is a 66 Coronet fwiw.
i have a 67 coronet and have thought about using nicer headlights. haven't messed with it yet.
looks like our cars use an H5006 headlamp so you could use this kit..
http://www.myhellalights.com/index.php/p...rsion-headlamp/
i thought about using a 146mm dual beam lamp and then putting some yellow fog lamps in the inner position. easiest way to do that would be to use relays and use the factory hi/low wires to activate the relay, new wiring from the relays to the lamps.
I like the way the glass is fluted,it puts a line on the top of the light beam,When you pull up behind another car,the line goes straight across the rear of the car in front of you!Also the bulb can be increased from the 75 watt that comes with it to 100 watt grin
oh yeah, I've had mid 80's water cooled VW's because they are fun as hell autocross cars. The Euro spec lights i've installed on them do that. I like that light pattern.
