I've got a 76 Duster W/ a slant 6 and Holley 1 barrel carb and it will completly die on accelration right off idle unless you really baby it.It does however run fine after getting it going.
The carb is a rebuild from Holley and I've replaced the accelerator pump, fuel pump and fuel filter and no change Any ideas?
