Originally Posted By NANKET
You can't compare the color of the seats from bench to buckets. They are usually different.
What does the car in the second picture have a RRGTX hood, satellite dash trim, sport satellite gtx Buckets, and a 2 spoke steering wheel. 8 track expel looks home made in both cars, where did the bottom of it go?
Is that the example from a flipper or car lot that doesn't care about doing it right?
The seats aren’t the big deal here. Is all the other parts of the interior. A 68 B-body maroon kick panel, console, defrost vent, seat belt, column cover, etc will not match a 69 B-body.
The 1st pic was listed as a low mile car. Seats look replaced.
Color of bench to bucket is different if it’s a two tone or has a cloth insert. Typically one of the bench colors matches the buckets.
