Originally Posted By Moparmad
what does? the toggle switch?
I guess I could do the toggle switch for now and get a transmission later.
any other options anybody?
there is no toggle switch in that kit.
there is a vacuum switch that will unlock the T/C if you floor it. there is an oil pressure switch that will engage LU above a certain mph. that's is for controls, everything else is wires or fuse.
You don't have an OD version so that part is not applicable.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
