Are you asking for measurements of the holes in the brackets themselves, or of the mounting holes in the subframes? Are you making some dollies? I can help with the fronts, but I haven't removed my rear brackets yet.
Btw, if you're making dollies, I can show you what I did to incorporate a lifting bracket with the dollies (so you can install the engine from below).
