If there is no vacuum loss and provides boost I think the booster can be ruled out. It sounds like there could be air in the lines. With engine off the booster should have a vacuum reserve. After one or two applications of the pedal that should have bled off. Pedal at this point should be rock hard provided there are no leaks and no air in the system.
