Do you want factory correct as of 1970 or something modern that works better? You can buy new oil drain plugs from a Dodge dealer for the Dodge Ram or something like that. It is a nice heavy duty bolt with a large rubber type washer. The new ones are OE correct but not OE correct for 1968.
