the nose fits VERY tight in a machined hole in the bellhousing, is it possible the nose of the starter broke when installing? I had to hone the hole out on mine
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
