I can't think of a reason not to build the siamese block. Use a 7.1 rod with GM ends (2.2/.990). On the street...it will live forever if it's done right. GM ends let you buy a more common rod/bearing, plus it takes a little weight out of the already heavy Hemi rotating assembly. Go bigger if you can, usually very little cost difference between a 528-540-572" combo.
