Hi, is there anybody out there that owns a 1970 or 1971 'Cuda/Barracuda convertible that can give me a measurement? The measurement needed is the width of the rear Deck Filler panel. As you know, the convertible uses a smaller width piece than a hardtop. I need to modify a hardtop piece and the original piece is no longer available to take measurements from. The places I need measured are in the photo below. Basically, I need the measurements of the three black lines. To be clear, it is only the visual part when the trunk is closed and the center molding is attached. I understand that the two end measurements should be the same. Any help will be greatly appreciated. Thanks.
https://ibb.co/12d2dz5
