Originally Posted By AndyF
If the 4781 was rich at part throttle when 12.5 at WOT then you probably made the very common mistake of using the main jets to tune for WOT. You should use the main jets to tune for cruise and then add extra fuel for WOT with the power valve circuit.
This.
