How do they handle header heat? Usually any material exposed to heat for an extended period of time seems to change states. Do they stay soft if that makes sense? I have used several heat wraps and they all get hard and brittle over time. Maybe Doug can give us the longest duration test result.
Also, would it last on the street? I assume Dragweekers and the like are using them?
