there are few different lengths pushrods, the pre 5.7s being the shortest,.
My next question would be , "are the heads milled " the oil travels thru slot in the bottom of the head from the block passage to the head bolt hole that feeds the rocker arms. I've seen pre eagle heads mill enough to effect the flow.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
