I have a 2007 Jeep Patriot and having problems with the windshield wipers.
When they started acting up they would go very slow and not work at times.
They do not work at all now. I checked the power and ground going to the motor. All seemed ok, so when I would ground the motor and linkage to the battery they would work. Also when the Jeep is on and you turn the wipers on the dash would light up like a xmas tree and you will see bu5 as the info. Tried the wiper switch and the turn signal switch no change. Must be Tipm?
Mopar ss# the rebuilt one $375.00 to a new one $1000.00.
What to do.
Thanks Bob
