Finally got a chance to look at this. The pressure in the rear servo is about 135psi in low gear, then drops to about 125psi with the brake engaged. Will turning up the pressure fix this? or do I have a deeper problem that is going to require trans disassembly and inspection? As always, thank you for your assistance.
bow
