I remember being in the staging lanes at the track one time and there was a guy chatting with the owner of this 69 a12 4 speed car that was running high tens. I don’t recall what the question was, but the answer was, “I’ve broken everything you can break from the block rearward......and a few things more than once”.
That’s the thought that comes to mind when I think: heavy car, 833, nitrous.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
