You’d still need to use the spacer plates with the x-ram intake, and without the heads and spacer opened up to MW size, there will be a pretty sizable port mismatch.
I had a customer who wanted to do the same thing intake wise, really just for the looks........ I just opened up a set Stealths.
The report I got was it worked fine.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
