last 2 quick builds I did were short block 68223196AB $2900,+ a set of Eagle heads (53021608DF $325 each) swap valve springs over to Psi 1515 (265 from speedlogix) Comp cams 270 VVt ($685---yes cams are too F--ing expensive. Ritter Drag pak from MMX for $700 (short version) Comp pushrods $120 Short Block= $2900 Heads + vavle springs $1000 Cam $685 ATI 918487 Damper $379
5k out the door not including my labor($500) and shipping. yes they need to buy their own front cover($50-250) and oil pan ($50-500).
Rockers/shafts/etc? Valve covers?
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
