They are single shaft rockers. They are roller bearings on the shaft. If I am going to use one jet to feed both sides should I start with like a .060 restricter? It is a hydraulic roller. The reason I am asking is I don't have a lot of oil pressure when warmed up at idle. It only has like 25lbs. Once I hit the throttle it goes right up. I was just wondering if I was loosing too much out the rockers.
Brandon
