Depends on the heads and the piston shape and the fuel as well as other things but typically a BB Mopar with aftermarket heads and a flat top piston will like 34 degrees of timing. Maybe more, maybe less but any new build I work on we start with 34 and work from there. 28 seems a little low for max performance so you might have something else going on with that combination.
