Ok.....after a trial fit , TALL is the word !!! yes...after everything in place. and keeping my 67 mounts, if I shim the mounts 3/8-1/2, everything clears, and the hood closes fine.
But it is a thight squeeze I have 1/4 inch clearance on the pass side shock tower.....LA headers will fit on the MAgnum heads ???? Do you have the same mounts as I do ? Daniel
