I like a blanket 'cause I personally saw a shield turn into a yellow ball of yarn that did NOTHING to prevent fragments from coming through the floor. Driver almost lost his foot.
Many of you heard me tell that above story before.
The drivers foot and toes basically turned black, and the doctor was prepping to remove a large part of it when he brushed across the toes. The patient groaned when that happened, and then the doctor did it again.
At this point the driver said why did you do that again? Doctors reply, you can feel that? Well, then, we need a different approach...…
Do you have trans. temp issues with Blanket? I'm not opposed to a blanket aside from the temp issue
