For brakes, I use a mityvac, and put teflon tape around the bleeder screw, to help keep it from eventually seizing to the caliper, and to help prevent air being sucked past the threads.
Last master/slave cylinder set up I bought came completely assembled, was all plastic, with fluid, and bled, all in 1 box. No bleeder screw on any of it.
