Handling guys running SS springs often run two the same (eg two rights). You could do the same... if you like the way it drives with SS springs.
I am running XHD + 1 full leaf on a Challenger. This is a less extreme bias design. Also 1" T bars up front. This works well and no extreme L/R height difference.
