Need a 70 Challenger patch panel for the fwd lower section of the passenger side rear quarter panel. This is the lower section from the aft end of the passenger door jamb to the contour of the front section of the rear wheel well opening and extends up to the small lower contour body line (Not the main body line). I personally seen a patch panel which was made by Sherman. That panel was awful. The lower contour line and wheel well contour and lines did not match. Panel looked as if the drop hammer press was weak or most likely the stamping mold was not detailed. I have come across a patch panel made by Goodmark on the internet. The picture is hard to tell if it is any better than the Sherman panel. Anyone have any experience with the Goodmark repair panel? Sorry for the lengthy post.
