I’d set it up 100% per original settings, then tune from there. I’ve always felt that if you have to go much off the original jetting spec with a basically stock Holley carb, then there’s likely issues elsewhere that need to be found and addressed. I’d start questioning anything more than 4 jet sizes off spec., personally.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
