Whichever piston you run, you should zero deck the block or at least have a fresh machined deck. If your gonna half azz it you should just toss rings and bearings in it.
Yea, domed pistons are so old tech, dont ever try to run gas ported nitrous domed pistons, modern ring pack and closed chamber heads, you might just go really fast.
