Calvert has answered this MANY times. 2-4 degrees down, with stated preload. You will be able to adjust preload without worrying about its effect on angle (within reason) at this setting.
Think about it...4 degrees down without bars, on a leaf spring set up works well, and the Caltracs limit spring wrap up..makes sense.
