I like the oddball dyno stuff.
Scott Harms built and dynoed a long ram 413 on here a few years back and that was interesting. I liked your post about the 318 junkyard turbo you did awhile back and your Hemi with the tunnel ram and thermoquads. And just to be sure, you have the "long rams" with the short divider right? (I think they're 16"?). If you could find a long ram with the long divider to compare to and a stock 4bbl that would be icing on the cake. I always thought the long rams would be good for a towing application
