Rod side clearance is more just for proper rod location without it moving too much side to side, not for maintaining oil pressure. Depending on what rods are used, clearance to block might be something to look at. Rods with through bolts and nuts create more interference than rods with cap bolts. But using the smaller BBC pin will help keep the overall rod width a lot narrower.
